January 3, 2020 by Nadeem
Want to learn how to bind an isolated hole in a vehicle carpet? Check out this step-by-step tutorial by Brent Parker of Brent Parker Motor Trimming in Glenorie, Australia.
“Sometimes it’s nice to not have to put a cut in from the edge of the carpet to bind the hole,” said Brent. “I’m sure a lot of you know how this technique is done, but for the guys who don’t, here’s how it’s done.”
1. Cut your carpet and binding material
Cut the hole you require in the vehicle carpet. Be careful that it’s the correct size and location. Otherwise, you could ruin the project.
Next, cut two square pieces of material about an inch bigger than the hole. I’m using some cheap vinyl to illustrate.
The Hog Ring - How to bind a carpet hole
2. Trace the hole on your binding material
Put one piece of vinyl underneath the carpet face-down and trace the hole.
3. Sew the binding material
Place the two pieces of vinyl together with their faces touching, and the marked one on top.
Sew the two pieces together following the shape of the hole you traced. Be sure to use a small stitch length.
4. Cut out the hole
Cut out the inside of the circle, keeping close to the stitches.
5. Flip the binding material inside-out
After you cut the hole, turn the vinyl the way it’s meant to be — face out, with the seam on the inside of the circle.
6. Mark the circle
Using a vinyl pen or chinagraph, mark the circle where you will stitch the binding to the carpet.
7. Glue the binding material to the carpet
Glue one side of the vinyl binding material and the backside of the carpet together.
Make sure that the stitches are touching the carpet so that it’s even all around.
Turn over the carpet and pull the binding through the other side.
8. Sew the binding material to the carpet
You’re almost finished! Take the carpet to the sewing machine, make sure you give it tension, and start sewing on the line you marked slowly and carefully —  tensioning as you sew because you want it even all around.
9. Trim the binding material
Lastly, trim the excess material off your binding, staying close to the stitches. Be careful to keep it even.
Here’s the finished product:
To see more of Brent Parker Motor Trimming’s work, follow them on Instagram and Facebook. Also, check out The Hog Ring’s “How To” section.
Filed Under: Archive, How-to, Pro Tips, THR Favorites Tagged With: Auto Trim, Auto Upholstery, Brent Parker Motor Trimming, Car Interior, Carpet, Carpet Binder
  1. McHenrys says
    August 21, 2017 at 10:17 am
    Only thing is a sharpie should never be used on vinyl
    • Kevin Balser says
      July 13, 2021 at 1:04 am
      AMEN !!
  2. plunge pools says
    October 16, 2018 at 9:58 am
    Amazing!
  3. Guy Galipeau says
    May 23, 2019 at 5:39 pm
    what a great idea– thank you for sharing. – I’ve been looking for a way
  4. Brent Parker says
    July 5, 2019 at 8:01 pm
    It was simply a scrap piece to show how its done.
    • Oliver Reiff says
      January 6, 2020 at 4:55 am
      ♥️✌️much thanks & appreciation for the tips n tricks!
  5. James Ayres says
    January 3, 2020 at 1:44 pm
    Two points, no need to back stitch on the start as you’ll connect on the circle, and you don’t need to use a single foot.
  6. William says
    January 3, 2020 at 4:09 pm
    This method works for leather as well but I should warn you to take care of unfinished edges on vinyl because over the years it can fray. One of the ways to protect the vinyl from fraying is to imagine at least a half inch larger than the finished edge and making relief “V” notch cuts all the way around the circle. Glue the entire back side of the top vinyl piece wait for the glue to dry then turn all your edges under, then sew it down about an eighth of an inch from the edges. Leather is different where all you have to do is burnish the edges to keep it clean looking.
  7. Bob morgan says
    January 4, 2020 at 3:27 pm
    Brent – “Thank you” for taking the time to share this. Always enjoy learning from the masters!
  8. Jack Davis says
    April 17, 2020 at 11:58 am
    My father taught me years ago I have done lots of. Them I use leather instead of vinyl you don’t have to worry about edge fraying,
  9. Nickson says
    October 25, 2020 at 7:47 am
    Waaaaaaaaaaaal thank you would love to learn more. Very straight forward tutorial keep it up
  10. Johnny Ritcheson says
    February 9, 2022 at 7:48 am
    thank you! I struggle no more !!! LOL
  • It’s Almost Collector Car Appreciation Day
  • A Journalist Visited an Upholstery Shop and Wrote a Love Letter to the Craft
  • Are ‘Zero Gravity’ Car Seats Safe in a Crash? China Wants Answers
  • Everything We Covered in May 2026
  • Volvo Wants to Put Wool Upholstery in Every New Model
