July 10, 2013 By Naseem Muaddi
“How much to slap a new vinyl top on my car?” Um… sometimes upholstery should be the least of your customers’ concerns. In situations like this, I’d probably recommend forgoing a new top for a whole new car.
What would you tell a customer who brought a car like this into your auto upholstery shop?
Filed Under: Archive, Funny Upholstery Repairs, THR Favorites Tagged With: Auto Trim, Auto Upholstery, Car Interior, Vinyl Top
  1. CTIbyFred says
    July 10, 2013 at 4:28 pm
    I tell the customer before I can give them an estimate they need to remove the old vinyl and fix the rust. The number one thing that a customer will argue with you is that his car has no rust. Every and I mean every car with a vinyl top needs to have the rust repaired.
    I have made it my policy to only install vinyl tops on cars that have already been to the body shop.
  2. papasage says
    July 10, 2013 at 10:43 pm
    had one like that i went to a salvage yard and cut the top skin of as close to the trim as i could ans laid it over the old top ans poprivited it along the edge added a pad and put a new vinyal on it ‘
  3. Mark Zito says
    July 11, 2013 at 12:29 pm
    Just grind it and sand, a little primer, you make a few hundred extra dollars. He’ll I found a .22 cal bullet under a top once, guy lived near a state game lands. I never turned down fixing the rust. Pussies!
    • Marcus says
      August 7, 2014 at 7:03 am
      Thats what the hell I’m talkin about!!! Balls!!! All u gotta do is grow some. No good shop would turn down the job. They explalin, charge, and get the work done (The correct way) to get the customer right, keep their reputation strong and their customer base expanding by word of mouth. Dumbest way to loose a client is by sending them away.
    • Reggie says
      December 5, 2022 at 10:30 am
      Not that easy, some extensive rust requires major repair the owner won’t want pay for, Pussy
  4. Riki Nazeboo says
    October 22, 2016 at 10:17 am
    Just started to play Rust and I am addicted, highly recommented.
  5. jim barnes says
    January 30, 2019 at 2:21 pm
    IS THIS STILL BEING PUBLISHED ?????
    Jim @mccoysupholstery.com
5 Souped-Up Sewing Machines
