February 24, 2012 By Naseem Muaddi
Nothing sets off an upholstery job better than a straight French seam or topstitch. Combined with thick thread, the job really pops. In fact, you’d be surprised by how much of a difference the width of thread can make in the overall appearance of a vehicle’s interior.
I was first drawn to the look of thick-thread decorative stitches by the dashboard and door panels of a 2011 Jaguar XKR. The thread’s width, the way its color contrasted with the dash and how perfectly straight its seams were instantly drew my attention. I knew right away that I wanted to experiment with the look in my own work. Now I can with QTC Contrast T-270 Bonded Nylon.
QTC Contrast is a new product developed by popular demand. The bonded nylon thread comes on 8 oz spools at 800 yards per spool with a break strength of 49 lbs. You can choose from a pallet of 12 colors and use the thread on any industrial strength sewing machine. Just make sure to wind a bobbin with the same spool and change your needle to the recommended size of 24-26.
QTC Contrast costs $22 a spool. Contact Tim at George Shaw & Associates Inc. to purchase one for yourself.
Believe me, the bold look of QTC Contrast will make your French seams get noticed.
Filed Under: Archive, Products & Reviews, THR Favorites Tagged With: 2011 Jaguar XKR, Auto Trim, Auto Upholstery, Car Interior, Contrast Thread, George Shaw & Associates Inc, QTC Contrast
  1. rebellion industries says
    November 3, 2012 at 7:03 pm
    I know this is an old thread, but what changes did you have to make to your machine besides needle size and tension (ie. Timing)? If you have used this thread did you also use it for the bobbin?
    • Naseem Muaddi says
      November 5, 2012 at 3:09 am
      Rebellion, you’ll have to wind your own bobbin to match the thread. If you’re using an industrial machine you shouldn’t have to worry about any adjustments beyond the needle and tension.
      • PM the Moccain Maker says
        September 21, 2016 at 7:30 am
        I used QTC Contrast for top thread AND bobbin on my trusty Pfaff 145 H3, sewing 4-5 oz soft beautiful black cowhide Knee-High Moccasins I had HORRIBLE bobbin loops and was about to give up. One night at the machine I complained to God and said “I need a bigger needle”, knowing it would make bigger holes and pull the bobbin thread up, but to my surprise He said “No, you need smaller bobbin thread”, to which I said “NEVER!!”. My Teacher always matched top thread and bobbin thread and taught me the same, so this was Stitching Blasphemy!!–as far as I knew. But I figured I had nothin’ to lose, so I changed over my bobbin to my old standby Star Ultra Dee 12 (128) and it stitched–PERFECTLY!! I’m doing the same on a pair of Elk and buffalo ones at present. BELIEVE IT!!! IT WORKS!
        • Rick Evans says
          October 11, 2022 at 12:41 pm
          Thanks for the tip. I use a Pfaff 1145 and im unable to run T270 thread. I’ll give the smaller thread on the bobbin a try
  2. upholsteryman says
    December 15, 2012 at 3:54 pm
    thanks alot ,i got my answer…
  3. blondee says
    December 21, 2012 at 5:30 am
    im having a huge problem with shredding any suggestions ? i have used it to do spiderwebs and all kinds of patterns but i am trying to do a simple french seam and it just wont go its on leather and im getting so frustrated help help help
  4. stichn says
    December 22, 2012 at 3:39 pm
    Problem could be more than one thing. Start with the needle. Are you using a diamond or other cutting point needle or just a round point? Tension could be too tight is you didn’t adjust for thicker thread. Less likely it could be the spacing between your needle and hook. Just some things to check if the problem doesn’t occur with the lighter weight thread.
    • stichn says
      December 22, 2012 at 5:10 pm
      I forgot to mention on the needle, you will need a larger needle as Naseem referred to above 22-26.
  5. Dave says
    January 3, 2013 at 2:14 am
    In my experience, Nylon doesn’t have the lasting power of Poly when constantly exposed to the elements. Convertibles, bike seats, boat cushions are all done in Poly.
    I wonder what skin it is off the supplier’s back when your customer comes back in 5-7 years and says the seams are busting due to UV rot? I guess it matters more what guarantee you put on your work than on what the supplier claims.
  6. Richard says
    January 3, 2013 at 10:51 pm
    I’m not a fan of the 270! It just looks too big! FWIW Katzkin uses 210 on theirs and it looks about right!
    As far as the bobbin a fellow upholsterer that has been in the business almost 40 years recommended using a standard size thread on the bobbin. It seems to work a little better plus it’s a whole lot cheaper!!
  7. jim says
    January 27, 2014 at 2:36 am
    I have just started using the QTC, and it awsome , but I cant find the # 24 needle for my consew 226, any ideas on a supplier?
    • Tim says
      August 16, 2017 at 1:57 am
      I also need to find needles for my consew I have 226 Rb machine plus a 336 consew double needle Machine I’m brand new to the group and also need to find a supplier for the thread I also love the look of the big thread but didn’t know where to find it
  8. rkaiser26 says
    April 2, 2014 at 5:42 pm
    can i use this thread on steering wheels and other hand stitched items?
  9. Ron says
    March 26, 2015 at 5:51 pm
    What machines will sew with this heavy stuff???
    Will a 255RB3 handle it??
    PLEASE!!!
  10. Master Worker says
    July 14, 2015 at 3:32 am
    experimenting with this thread… or should i say, trying to experiment. we have a juki walking foot machine and I’m having a hard time finding a needle short enough. any suggestions? I was supposed to deliver a job a week ago. Have thread, three boxes of needles later, my supplier still can’t help me sew with it.
  11. Dale Williams says
    August 21, 2015 at 7:34 pm
    Does anyone know if this thread will perform on an Adler 67 Walking Foot Machine?
  12. Cesar says
    August 25, 2015 at 6:05 am
    Most of the industrial sewing machines can work with thick threads…it all depends of the appropriate needle…if I am going to use a thick thread then I should use a thicker needle e.g. 180 (european measure)=24 (american measure) 200=25
    The needle plate should have a hole, enough, to let the needle and its thread, pass down through freely…if necessary change the plate, or buy another for this purpose and widen the hole with a tungsten drill bit.
    Tensions should be regulated also…the ‘upper tension’ is adjusted simply by loosening its nut. The ‘lower tension’ in the bobbin case has two little bolts…to do the adjustment, just loosen a little the first tiny bolt…don’t touch the other one.
    I think these thick threads could be used for special cases as decorative stitches…besides, as Naseem said, they easily run out of thread in the bobbin.
    Another tip is that the thread should be the same thickness up and down to get an evenly lockstitch.
    • Tim says
      August 16, 2017 at 2:01 am
      I use mismatched thread size on my machines all the time with good results
  13. Detonnek says
    November 19, 2020 at 1:55 pm
    Medical news about 633283140 products https://www.facebook.com/Obzoroffinfo Best reviews in 42729736 articles.
    6_57440
    We publish articles about diabeteson 19 lamguages for 69 countries!
  14. kbh games says
    June 8, 2023 at 9:04 pm
    Thank you immensely for crafting such an exceptional piece. This post is a testament to your talent and dedication.
