Did You Know Sunscreen Can Damage Car Interiors?
June 23, 2025 By Naseem Muaddi
The Hog Ring - Did You Know Sunscreen Can Damage Car Interiors?
If you’ve been in the auto upholstery business for a while, chances are you’ve come across that mysterious oily stain on a headrest or seat bolster and thought, “What is that?” More often than not, the culprit is something most people don’t even think twice about — sunscreen.
It makes sense when you think about it. People apply sunscreen right before a drive to the beach, the park, or the job site. A little on the back of the hand, a smudge on the leg, and suddenly it’s on the leather, vinyl, or fabric of the car. Because sunscreen is designed to stay on skin even in harsh conditions, it doesn’t exactly wipe off easily once it transfers to upholstery.
The Chemicals Aren’t Kind
The problem isn’t just the mess. Sunscreens are full of active ingredients like avobenzone and oxybenzone, which are great for blocking UV rays but not so friendly to car interiors. When left on a surface exposed to heat and sunlight, these chemicals can oxidize and cause staining or discoloration. On light-colored leather, especially, you might notice yellowing that’s hard to explain — until you realize someone leaned back with a freshly lotioned neck.
More Than Just Leather
Vinyl and plastics aren’t immune either. Over time, the oils and chemicals in sunscreen can break down synthetic materials, leaving surfaces tacky, faded, or even cracked. And since many drivers keep sunscreen in the glovebox or door pocket, accidental spills are more common than you might expect. One forgotten, half-melted tube can do a number on door panels or seat fabric.
How to Clean It Up
Cleaning up sunscreen isn’t impossible, but it does require the right approach. For leather and vinyl, a gentle interior cleaner with a microfiber cloth usually does the trick — provided the mess is fresh. Older stains might need a leather-safe degreaser followed by a pH-balanced conditioner to restore suppleness and even out the finish. On fabric seats, a foaming upholstery cleaner can help lift out the residue, but you’ll want to avoid oversaturating the area. As always, spot testing is your friend, and time is of the essence.
A Subtle, But Common Threat
It’s one of those small, easily overlooked details that can add up to big headaches for car owners — and opportunities for skilled interior pros. So the next time a customer complains about mystery stains, you might want to ask if they’ve been staying sun-safe.
  • How to Remove Pink Stains from Marine Upholstery
  • Hand Sanitizer Will Ruin Your Custom Steering Wheel
  • Toyota’s Self-Cleaning Car Interior is a Germaphobe’s Dream
Filed Under: Archive, Care & Maintenance Tagged With: Auto Trim, Auto Upholstery, Car Interior, Sunscreen
5 Souped-Up Sewing Machines
