Porsche 911 Convertible Top Replacement: How We Fixed a Common Factory Seam Issue
February 27, 2025 By Gary Dekirmendjian
The Hog Ring - Porsche 911 Convertible Top Replacement
When it comes to luxury sports cars, few models are as iconic as the Porsche 911 — but its convertible top has a serious problem.
Like any convertible, the 911’s soft top is susceptible to wear and tear over time. One particular issue we’ve encountered repeatedly is a French-style seam that while looking good, can cause premature failure in certain models.
At OEM+ Auto Tops, we provide high-quality convertible top replacements that not only restore the vehicle’s appearance but also improve its durability. Here’s how we did it for the Porsche 911:
Identifying the Factory Seam Issue
The factory seam issue in Porsche 911 convertibles typically manifests as a weak point where the top connects near the rear window or side panels. Over time, exposure to weather, UV rays, and repeated opening and closing of the top can cause stress on these seams, leading to:
  • Fraying or separation of the stitching
  • Water leaks into the cabin
  • Visible fabric deterioration
  • Wind noise due to improper sealing
Unfortunately, many Porsche owners only notice the problem after the damage has worsened, making a replacement top the most viable solution.
The Replacement Process
When a client brought in their Porsche 911 for a convertible top replacement, we immediately had a look at the factory seams to confirm the issue. After diagnosing the problem, we walked the client through our process and assured them that the replacement would not only resolve the seam issue but also extend the lifespan of their soft top.
Here’s how we tackled the replacement:
  1. Removing the Factory Top – We carefully disassembled the worn convertible top, ensuring that no damage occurred to the frame or surrounding components. We were cautious in removing the headlining panels and trim, and we kept an extra pack of plastic clips we sourced from the dealership to replace any that broke.
  2. Addressing the Seam Weakness – Before installing the new top, we reinforced the problem areas using high-strength thread. The new top uses the same seam style to preserve the original appearance, but modified to last longer. We used a closer stitch length and sewed 1.5mm deeper than the original, and additionally heat-bonded and sealed the cut edges to keep it waterproof.
  3. Precision Installation – Using our expertise and specialized tools, we fitted a premium aftermarket top that closely matches OEM specifications while incorporating improved seam reinforcement.
  4. Weatherproofing & Testing – To ensure a flawless finish, we applied weatherproof sealants to rejuvenate the old weatherstripping, and conducted rigorous water and wind tests to verify the integrity of the new top and confirm we installed everything correctly.
Why Choose OEM+ Auto Tops?
OEM+ Auto Tops specializes in manufacturing premium convertible tops for modern cars, from Mustangs to Ferraris. We’re known for:
  • Experienced Craftsmanship: Our professionals have years of experience and access to a thorough convertible top installation guide for precision and efficiency.
  • Unparalleled Customer Support: We provide a 5-year warranty and offer the highest labor compensation policy in the industry, paying trim shops $75 per hour in case of warranty claims.
  • Commitment to Excellence: We prioritize quality, ensuring every top meets our high standards.
By choosing OEM+ Auto Tops, trim shops can rest assured that they’re installing premium products that will bolster their reputations. Our commitment to quality ensures that every installation meets or exceeds factory standards, preventing common issues like factory seam defects from recurring.
Contact Us Today
If your client’s Porsche 911 convertible has fraying seams, water leaks, or excessive wind noise, it may be time for a top replacement. Addressing these issues early can prevent further damage and maintain the vehicle’s luxurious appeal.
At OEM+ Auto Tops, we specialize in high-quality convertible top replacements that enhance durability, performance, and aesthetics. Contact us today to learn more about our products and register for our preferred installers list.
You can visit us at oemplusautotops.com. You can also follow us on Facebook, Instagram, and YouTube for updates, tips, and insights.
  • Watch the Porsche 911’s Soft Top in Action
  • How OEM+ Encourages Professional Installation of Convertible Tops
  • OEM+ Auto Tops is Setting a High Standard in Aftermarket Tops
Gary Dekirmendjian is Production Manager at OEM+ Auto Tops
Filed Under: Archive, Site Sponsors Tagged With: Auto Trim, Auto Upholstery, Car Interior, Convertible Top, OEM+ Auto Tops, Porsche, Porsche 911
