Flush-Mount Window Bonding: How OEM+ Auto Tops Sets a New Standard
May 23, 2025 By Gary Dekirmendjian
The Hog Ring - Flush-Mount Window Bonding by OEM+
Tired of window separation, leaks, and poor alignment on aftermarket convertible tops? OEM+ Auto Tops has engineered a solution that not only matches OEM convertible tops—but exceeds them in every way.
We’re proud to introduce our Flush-Mount Window Bonding System—an innovative breakthrough designed for industry professionals who demand precision, performance, and longevity in every stitch.
The Problem: Window Separation on Soft Tops
Convertible soft tops often suffer from one major flaw over time: the bond between the rear glass and the top fabric fails. You’ve seen it—gaps, leaks, even complete separation. It’s not just a cosmetic issue; it compromises the entire top’s performance and lifespan.
That’s why we developed a proprietary flush-mount system for bonding glass that delivers a perfect factory-style finish with zero separation—no gaps, no failures.
Designed with Precision, Modeled for Perfection
At OEM+ Auto Tops, we don’t guess. We digitally scan each rear window, capturing a 3D map of its exact perimeter. That scan becomes the blueprint for a 3D-modeled injection mold, ensuring the flush-mount frame fits the glass with millimeter accuracy—every time.
Whether it’s the Porsche 991/992, Mercedes C-Class or E-Class, or Volkswagen Beetle, our flush-mount system blends seamlessly with the OEM silhouette, elevating the look and eliminating tell-tale signs of aftermarket work.
OEM Construction, Reinvented for the Real World
Every part of the flush-mount system is built in-house—from digital design and tooling to final production. This lets us prototype rapidly, test rigorously, and maintain total quality control.
We construct each frame from UV-resistant plastic, engineered to withstand long-term sun exposure without fading or cracking. For models with articulating windows, we mold in metal pivot brackets—ensuring full compatibility with OEM hardware.
The Bond: Waterproof, Durable, and Built to Last
Our system uses a high-strength urethane adhesive, applied as a precision bead around the glass. This adhesive doesn’t just hold—it locks in a 100% waterproof seal that resists leaks, moisture intrusion, and delamination.
Added features like threaded insert grooves make headliner installation smoother and more secure, while integrated molded grooves ensure a clean, finished look with every build.
Why Flush-Mount Window Bonding is the Future of Soft Tops
More than just sleek—it’s smart. Here’s why more trimmers and builders are switching to OEM+ flush-mount solutions:
  • True OEM appearance for a factory-finished look
  • Zero window separation—permanently bonded with advanced gluing techniques
  • 3D-modeled molds for superior fit and alignment
  • UV-stable materials that hold up in harsh climates
  • Molded metal brackets for articulating glass compatibility
  • Threaded grooves for quick, clean headliner installation
Built by Engineers. Trusted by Trimmers.
Our flush-mount window bonding system reflects the heart of what OEM+ Auto Tops stands for: innovation, craftsmanship, and long-term value.
We don’t just manufacture convertible tops—we reimagine how they should perform. So when your customer wants something better than stock, give them a reason to say yes. Choose flush-mount from OEM+ and install with confidence.
Want to see the difference?
Check out the photos below and contact OEM+ Auto Tops to learn more about how our flush-mount systems can upgrade your next build.
To learn more about our products or register for our local installers list, visit oemplusautotops.com. You can also follow us on Facebook, Instagram, and YouTube for updates, tips, and insights.
  • Next-Level Convertible Tops with Folded-Edge Bonding
  • Porsche 911: How We Fixed a Common Factory Seam Issue
  • How OEM+ Encourages Professional Installation of Convertible Tops
Gary Dekirmendjian is Production Manager at OEM+ Auto Tops
Filed Under: Archive, Site Sponsors Tagged With: Auto Trim, Auto Upholstery, Car Interior, Convertible Top, OEM+ Auto Tops
