August 31, 2025 By Gary Dekirmendjian
Whether you’re restoring a vintage convertible or upgrading a modern roadster, selecting the right replacement soft top is key to achieving a clean, professional result. From material quality to proper fitment, here’s what our team at OEM+ Auto Tops believes you should keep in mind when guiding your clients — or placing an order yourself.
1. Don’t Skimp on Specs
Always start with a top that meets or exceeds OEM specifications. This ensures proper frame tension, correct bow alignment, and factory-style appearance — especially critical on high-end or collector vehicles. Deviating from OEM specs can lead to warranty issues or fitment problems.
2. Material Matters
Most convertible tops come in either vinyl or canvas:
  • Vinyl is cost-effective, easier to maintain and suitable for daily drivers.
  • Canvas offers better acoustic insulation, longer life and a more upscale look.
Choosing the material that matches the original top not only preserves the intended appearance but also ensures compatibility with the vehicle’s retention and sealing system.
3. Window Type Impacts Installation
Plastic windows may be lighter and easier to install, but they degrade faster over time. Glass windows provide superior clarity and durability, but require precise handling and may need additional support hardware or defroster connections. Always verify what the original top had — especially when dealing with factory designs that rely on specific tension curves or shelf configurations.
4. Factory Color Matching is Crucial
Black isn’t just black. Factory soft tops vary in grain, sheen and tone. A close match may still appear “off” when installed. Use verified sources like Haartz to identify exact OEM color codes. This is particularly important when working with restorations or high-visibility vehicles.
5. Quality Indicators Are in the Details
When reviewing a top, look for:
  • Clean, consistent stitch lines
  • Heat-sealed seams
  • Multi-layered construction with sound-deadening cores
  • Reinforcement at stress points
  • Pre-punched holes for problem free installation
Cheap tops often skip these features, making them prone to leaks, wrinkles and early failure.
6. Don’t Ignore the Headliner
If you’re working on a luxury model with a fabric headliner, inspect it closely. A new outer top paired with a stained or sagging headliner compromises the entire job. Replacing both at the same time not only saves labor but delivers a more complete result.
7. Installation isn’t Always DIY-Friendly
Even seasoned techs can struggle with tight-fitting tops, especially those with bonded glass or integrated rain gutters. Make sure you have the right tools, adhesives, and know-how — or partner with a shop that specializes in convertible top installation. A well-installed top is what ultimately sets your work apart.
8. Know the Warranty Terms
Not all warranties are created equal. A solid one should cover:
  • Glass separation
  • Seam delamination
  • Defective stitching or hardware
  • Color fading within warranty period
Clarify warranty conditions before installing to avoid issues with customer claims down the road.
9. Use Reviews to Gauge Real-World Performance
Some tops perform better on paper than in practice. Online reviews, shop forums and trimmer feedback can highlight issues like poor fitment, brittle materials or window fogging. Doing a bit of research upfront can save hours of rework later.
10. Stick with Trusted Manufacturers
Avoid bargain-bin or unbranded tops. Manufacturers with a track record in OEM or high-end aftermarket products are more likely to deliver consistent quality and post-sale support.
Final Thought
A convertible top is more than a cosmetic upgrade — it’s a structural and functional component. As trimmers and installers, it’s our responsibility to recommend the right product and ensure it’s installed with care. With the right top and a professional install, you’re not just replacing fabric — you’re restoring the soul of the vehicle.
To learn more about OEM+ Auto Tops or register for our local installers list, visit oemplusautotops.com. You can also follow us on Facebook, Instagram and YouTube for updates, tips and insights.
  • How OEM+ Auto Tops is Redefining Convertible Top Manufacturing
  • Next-Level Convertible Tops with Folded-Edge Bonding
Filed Under: Archive, Guides & Manuals, Site Sponsors Tagged With: Auto Trim, Auto Upholstery, Car Interior, Convertible Top, OEM+ Auto Tops
