May 13, 2026 by Naseem
When it comes to tarps, marine canvas, agricultural covers, banners, and other heavy-duty fabric applications, Keyston Bros reminds us that every component matters. Even something as small as a grommet can have a major impact on durability, appearance, and long term performance.
Grommets may seem like a minor detail, but choosing the right type — brass, nickel or stainless steel — can help prevent premature wear, reduce maintenance issues, and extend the life of the finished product. Whether the application is exposed to freshwater conditions, salty coastal air, or everyday outdoor environments, there’s a correct grommet for the job.
Why Grommet Material Matters
Grommets reinforce openings in fabric where ropes, hooks, straps, or fasteners are attached. These areas often experience constant tension, friction, and exposure to the elements. Over time, moisture, UV exposure, and corrosion can weaken low quality hardware and lead to failure.
Using the proper grommet material can help:
  • Prevent rust and corrosion
  • Extend the lifespan of the product
  • Maintain a clean and professional appearance
  • Reduce maintenance and replacement costs
  • Improve reliability in demanding environments
For fabricators working in marine, industrial, or outdoor applications, selecting the right hardware is just as important as choosing the right fabric.
Matching the Grommet to the Environment
The Hog Ring - Choosing the Right Grommet for Long Lasting Performance 1
Different environments require different levels of corrosion resistance and durability. Here is a closer look at where each grommet material performs best.
Brass Grommets: A popular choice for general outdoor applications. They offer solid corrosion resistance, an attractive appearance, and an economical price point. For many tarps, covers, and banners used in standard outdoor conditions, brass provides dependable long term performance.
Nickel Grommets: Commonly used in freshwater marine environments. They offer additional protection against moisture while maintaining a clean finish that works well in marine canvas and boating applications.
Stainless Steel Grommets: For saltwater environments and coastal applications, stainless steel is often the preferred option. Salt air and constant moisture can quickly damage lower grade materials, but stainless steel provides superior corrosion resistance and long lasting durability in harsh conditions.
Small Hardware Choices Make a Big Difference
It’s easy to overlook hardware during the fabrication process, but the right grommet material can significantly impact the overall quality and longevity of the finished product. Choosing a grommet that matches the environment helps reduce failures, improve customer satisfaction, and protect the investment in the finished job.
From economical brass options to highly durable stainless steel solutions, Keyston Bros has you covered. They’ll quickly ship grommets to your shop from one of their 17 warehouses and branches across the United States. Of course, they also carry a vast inventory of other materials, tools and supplies.
To learn more about Keyston Bros, create a shop account, and shop for grommets, visit keystonbros.com. You can also follow them on Facebook and Instagram.
Filed Under: Archive, Guides & Manuals, Site Sponsors Tagged With: Auto Trim, Auto Upholstery, Car Interior, Grommet, Keyston Bros.
